chuckh1197
Member
Had a problem with starting IO-320 the other day and I assumed it was a starter problem as prop would only move a little , maybe 30-60 degrees but starter was spinning. Turns out my mechanic says it is something he has never seen in his entire time. The ring gear is slipping on the flywheel. Have to get a new flywheel and ring gear I guess. Any other ideas? Also have Lightspeed ignition so I guess it needs to have sensor activators attached. 122 tooth with a lamar starter.
Anyone have one for sale.
