I have used my Dremel a lot on my project but have always been plagued by the aluminum clogging the flutes of the cutter causing slow cutting. Well, I tried Boelube on the cutting bur and its like MAGIC! The bur continues to cut fast and does not clog! I have the Boelube in the solid stick so what works best is to heat up the cutter (by running it on the aluminum) and touching it on the stick. The Boelube melts and runs up into the flutes.
Stewart Willoughby
RV6, finishing.
Stewart Willoughby
RV6, finishing.
