Old 08-18-2019, 06:29 AM
Chris7 Chris7 is offline
Default VS-1015
Hi all,
Hoping someone can help me out here, I have accidentally over done the countersinking on the VS-1015. Wondering if anyone is close enough to their kit to measure the thickness because I forgot before I left my shop and now I won't be back for a week. If I have the aluminum I will just make a new one.
Otherwise I have to order which has some lead time with shipping to me.
Thanks!
Chris
RV-10 (Emp started, Wing inventory done)
First RV-10 build in Hong Kong
Donation made 2020
Old 08-18-2019, 08:24 AM
jacoby jacoby is offline
My doubler measures 0.063Ē.
Old 08-18-2019, 08:26 AM
Thanks! As I suspected I donít have that size. However I managed to find a friend who will be in LA this week so Iíve had it shipped to his hotel.
First lesson on paying closer attention!
Chris
Donation made 2020
Old 08-18-2019, 09:04 AM
Yeah I looked in the trim pack and there is nothing that thick.
FWIW I usually test the countersink on a piece of scrap bar before taking it to the part. Especially if Iíve changed from flush to recessed and vice versa or I donít know where I left it.
Iíve also thought about doing some sort of flag system but I havenít come up with something that works.
I did run into a problem with my countersink cage. The internal spring was too long and it would occasionally pop and sink anywhere from 0.002Ē-0.020Ē deeper. It actually ruined the vs main spar! I clipped that spring and it has worked perfectly since.
Old 08-18-2019, 09:18 AM
Yes I got a bit ahead of myself. I guess I should double check my spar too! from memory it didn't touch the spar caps so I think my main spar is ok.
From now on I will have a good piece of scrap ready to test
Chris
Donation made 2020
