Old 05-10-2019, 08:16 AM
Skot7ac Skot7ac is offline
Default RV-8 disassembly for transport
The New to me RV-8 made it almost all the way home. After takeoff on net last leg, the engine started running rough and the Dynon showed a cylinder about 100 degrees cooler that the rest. Short version is oil all over the belly and three cylinder base studs broken on the #1 cylinder . I will be pulling the wings and tail and putting it in a Uhaul for the final leg home. Does anyone have any advice for wing and tail removal? Headed down tomorrow for prep work and hoping to move it on Monday.
Scott
Old 05-10-2019, 08:38 AM
n6233u n6233u is offline
If you use an open trailer then you won't have to take the tail off. I used an enclosed trailer and removing the tail can be tedious, next time I buy one that needs to be transported I'll take an open trailer.
-Jim Pantas
Building: RV-7a
Flying: Hatz CB-1
Old 05-10-2019, 08:50 AM
bret's Avatar
bret bret is offline
Wow! so sorry to hear this, hopefully someone near you can help, the tail fasteners are easy but the wings are going to be the challenge, drain all the fuel, support the wings with saw horses and pillows, unhook fuel lines, pitot lines, wiring, aileron push rods, flap rods, flaps, gap seals. The close tolerance spar bolts will need to be driven out, this will require a lot of effort and a box of cuss words.
Old 05-10-2019, 10:21 AM
DanH's Avatar
DanH DanH is offline
Spar bolts = rivet gun with brass peen:
https://aircraft-tool.com/shop/detai...?id=ATS107A-3B
Probably will need some brass and steel drift pins to complete the removal.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-10-2019, 10:48 AM
Raymo's Avatar
Raymo Raymo is offline
A long pry bar on the spar bolts will help, too. Plan to replace them when the wings go back on.
Sorry for you luck!
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 05-10-2019, 10:51 AM
Robin8er Robin8er is offline
It's fairly straight forward. Having the plans available helps so you can see hows its put together. But basically you just remove the fairings, disconect the flight controls, pitot line, fuel lines and electrical wires, then remove the spar bolts and pull the wings and tail off.
Bring a drill with a flexible extension for the million screws on the floor board.
One thing that is very helpful for the wings is to use a saw horse with blankets on it to rest the wing on as you tap out the spar bolts. You will need someone to help unload the tension on the wing to remove the bolts. If its and rv 8, I recommend buying a wood saw horse and then cutting several inches off two of the legs so that the saw horse leans at the same angle as the wings in relation to the ground.
There are a couple smaller bolts in the wing spar that arent as obvious as the big ones. Try to remove those first so that you dont forget about them.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 05-10-2019, 11:09 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Default One gotcha
If you remove the tail, put the 3 tailspring bracket/aft bulkhead bolts back in for transport. Otherwise, the aft bulkhead will be ruined in a very short time.
Of course, this applies only when the ship is tied down with the tail wheel on the trailer...if you support the fuse with the tail wheel not on the surface, this caveat does not apply.
Best,
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
Old 05-10-2019, 03:35 PM
skylor's Avatar
skylor skylor is offline
Default Tail Weight
Depending on your empty CG (do you have a heavy engine and prop?), you may need to add some ballast weight to the rear of the aircraft before removing the tail and wings. These things can get quite nose heavy without the weight of the empennage and wings to balance the engine and prop.
Skylor
Old 05-10-2019, 08:18 PM
Ted RV8 Ted RV8 is offline
Slide hammer puller for wing bolts.
Made a mini one for getting into tight places.
Good advice from F1Boss regarding the tailspring bracket bolts. That one almost bit me on one trailering adventure. Luckily it was only for a short distance and didn’t do any serious damage.
Old 05-15-2019, 08:25 PM
Thanks all for the input, the wing bolts were indeed the worst part of disassembly. Everything fit into a 24 car hauler, now begins the reassembly and engine overhaul.
