Old 05-05-2019, 04:41 PM
Laird Laird is offline
Default Economical Injection switch from Carb
Iíve been thinking of converting my O-360 A1A to some kind of forward facing injection setup.
Cost is primary driver, not so much performance or acro.
Obviously Iíll need a new sump, high pressure pump, and all the bits. Cowling mods are no problem.
What setup fits the bill?
Thanks in advance,
Laird
Old 05-05-2019, 05:11 PM
RV6_flyer's Avatar
The best solution would be to contact Don at Airflow Performance and get him to set you up.
IMHO, he has the best system and it will be cost competitive with the lowest cost new system.
It can be installed on your updraft sump. If you really want a horizontal intake that will add another $1,500 US on to the FI system (~$3K), mechanical pump ($250-$300) and electric pump ($600-$1K).
I am going from memory on prices and they may be higher. Have not shopped for some of this stuff in a couple of years. Was surprised to learn Vac Gyro overhaul prices have gone up 50% in 4-years a couple of years ago and the overhaul price was the same price new gyros were 20-years ago.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 05-24-2019, 10:00 AM
Kalibr Kalibr is offline
Location: St John, Steamboat Springs, planet Earth generally
Watch out if you are set on replacing the sump ó a horizontal sump may not play nice with your cowling and exhaust. I am in the process of pulling a horizontal induction sump and replacing it with a vertical induction sump due to cowling and exhaust issues on my airframe (not an RV, but an RV4 would have a similar fitting issues). I am keeping the Airflow Performance FM150 FI and expect to fit it horizontally using a 90 degree elbow adapter they sell.
Building a Panther, but lurking here, like many others
Old 05-24-2019, 12:19 PM
Thanks for the warning but I already assumed that there would be cowl mods to do and possibly a new exhaust.
I guess it's coming down to whether to pick an Airflow Performance injector or Bendix. Everything else is similar.
Anybody have opinions on Airflow vs Bendix?
Laird
Old 05-24-2019, 12:32 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default AFP hardware
I have the elbow, filter adaptor ( for FM-200 /0360) and filter brand new. It didnt work for my SJ cowl. Make you a heck of a deal !
decamplarry@gmail.com
765-505-1160
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / Steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 05-24-2019, 04:52 PM
Bcone1381 Bcone1381 is offline
Follow Post #2's recommendation to contact Don. I am planning an installation on a non-RV experimental, and had a Bendix RSA fuel control. I followed his advice and did not to just ditch the Bendix unit. AFP did the overhauled the whole system. These injectors are tunable using AFP's parts.
Old 05-24-2019, 05:06 PM
Thanks, but I'm going to go with a forward facing sump.
I'll give Don a call when the time comes.
Thanks to all.
Laird
Old 06-11-2019, 09:57 PM
FlyFastJP's Avatar
FlyFastJP FlyFastJP is offline
765-505-1160
I emailed you, Larry. Interested your deal for my RV-4.
BearDog Racing
www.beardogracing.com
RV-4
Performance Propellers USA
Race #51
00R
Old 06-12-2019, 08:27 AM
Raymo's Avatar
Raymo Raymo is offline
PM me if you'd like a short video of my AFP setup with the 90 degree elbow.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 06-12-2019, 10:11 AM
rv7charlie rv7charlie is online now
Laird,
Just sent you a PM about a forward facing sump.
Charlie
