Old 01-16-2019, 02:04 PM
Joby Joby is offline
Default Forward and aft baggage areas on RV9A?
I bought a RV9A in November. In studying the Weight and balance section of the POH. It refers to forward baggage 122” aft of datum and aft baggage 144 inches aft of datum. I can see the aft baggage area but I can’t find the forward baggage area. Can someone help?
Joby Wieser
Old 01-16-2019, 02:21 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Joby Wieser
It's all one area. Starts just behind the seats (FB) and goes 24" back that stops at baggage wall (RB).
*Image for area reference only.
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 01-16-2019, 02:26 PM
YellowJacket RV9 YellowJacket RV9 is offline
Joby Wieser
The baggage area on the 9 is at 122” aft. 144” is even further back, and would seem to imply that the builder added an extra storage area. Is there a compartment behind the baggage bulkhead?
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 01-16-2019, 03:35 PM
airguy's Avatar
airguy airguy is offline
Chris
Not by the plans - but some people have installed long tubes back in that area to carry fishing rods. It's far enough aft that you certainly don't want to put any meaningful weight back in that area.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2020 dues paid
N16GN flying 560 hrs and counting! Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 01-16-2019, 03:41 PM
Correct, I should have asked if it looks like the builder ADDED a storage area behind the bulkhead. It is for sure too far back to put anything besides the lightest stuff.
Chris
Chris Johnson
Old 01-16-2019, 03:49 PM
There isn’t any other access aft of the normal baggage back wall. After further google search I found this pdf on line. http://www.vansairforce.net/poh/rv-9apoh.doc The POH I have is a copy of this POH with the serial number and tail number changed. The W&B. Is copied verbatium. Clearly I need to do an actual weight and balance on this plane.
Is there a downloadable procedure for doing this?
Thanks for all your answers.
Joby
Old 01-16-2019, 04:14 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Joby
Did you get the Van's Builder Manual with the purchase of the plane? If not, you should purchase a copy from Van's. Inside you will find instructions for how to do a proper weight and balance including the datum and all of the various arm lengths.
Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2020
Old 01-16-2019, 05:27 PM
Ralph Inkster Ralph Inkster is offline
First reaction I had was that the maybe the builder used portions of a RV-8 W&B report, but your POH numbers don't match that either.
Might be an idea to redo the whole weighing & calculate your own data to confirm the base data in the POH.
Ralph
Time to slow down the Builder Assist operation & concentrate on finishing my own stuff & fly the 6A.
My 'retirement' activities list;
Mon - 6 build project to finish
Tues - 6 upgrade project, canopy, panel, interior & fairings
Wed - 9A salvage rebuild, wing, firewall, gear, engine
Thurs - 7 salvage rebuild (was second plane I built, the Turbo Subie) for a buddy
Rest of week - belongs to the wife!
Old 01-17-2019, 07:16 AM
I found how to do the weight and balance in the big box of documentation I got with the airplane. Will do a new W&B, thanks for y’alls help.
Joby
Old 01-17-2019, 08:07 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Actually, a POH is a legal document required by a factory built airplane's type certificate. Experimental aircraft therefor cannot have a POH in the legal sense of the term.
And given all the variables in homebuilt aircraft -- engine, prop, equipment, etc. -- there can be a lot of variation in weight between airplanes built from the same kind of kit. One airplane's "POH" would have little relevance to another plane.
RV-9A at KSAV (Savannah, GA; dual experimental touch screens with autopilot, IFR GPS)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
