Old 12-08-2018, 11:50 AM
Stockmanreef Stockmanreef is offline
Default SS Foil for Firewall Insulation
Is 0.002 stainless steel foil OK for covering insulation on the firewall or should I use something thicker?
It seems that 0.002 is easy to come by, but I can't find a good source for .003. Or is thicker better?
Can someone direct me to a good source?
ken
Ken Stockman
Midland, MI
EAA Chapter 1093 member
RV-14a (serial number 140073)
N73XP (at least that # reserved now)
Old 12-08-2018, 12:04 PM
Default mcmaster
Here:
https://www.mcmaster.com/stainless-steel-foil
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 12-08-2018, 02:25 PM
DakotaHawk's Avatar
DakotaHawk DakotaHawk is offline
I'm coming up on the Firewall chapters for my RV-14 build. Is there a website or youtube video that gives a good explanation of the process of insulating and protecting the firewall?
"I didn't become an expert at any subject until YouTube came along!"
_______________________________
Scott "Grumpy" Stewart
RV-7 N957RV (First Flight on Dec 18, 2009)
RV-14 N144P (Empennage complete, wings almost complete, fuselage almost complete)
#866 on the Van's RV-7 hobbs
#6563 on Van's generic hobbs
Arlington, WA
Old 12-08-2018, 03:03 PM
Raymo's Avatar
Raymo Raymo is offline
Dan H and others have lots of info and photos linked to VAF. The local search feature is a bit complicated, IMO, but you can use other search engines with the following technique.
site: vansairforce.com firewall insulation
Here is the "how to" for the non-computer nerds out there
http://lmgtfy.com/?q=site%3A+vansair...all+insulation
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 12-08-2018, 03:12 PM
I'll be using .005 titanium foil, from www.titaniumgoat.com.
I think it's slightly easier on the hands. Due to the thickness, it'll be a bit heavier, just over half an ounce per square foot.
Old 12-08-2018, 07:21 PM
Dorfie Dorfie is offline
I used 0.002 SS foil on my firewall. Came out well and I am happy with the result.
You can cut it with scissors as well as a blade.
It is extremely sharp and will cut you if not careful.
You cannot drill a hole using a standard drill. It rips. Larger holes, 1/4inch and up you can cut with a knife using the hole in firewall edges as guide. Smaller holes like 1/8 inch I cut a cross into hole and then used a tapered grinding stone in a Dremel against firewall hole edges.
Johan
Dorfie
RV10 Flying, N245JM
2020 dues paid with a smile
Old 12-08-2018, 10:04 PM
Checkmate's Avatar
Checkmate Checkmate is offline
Default .005 SS
I used .005 SS Shim Stock. No wrinkled tinfoil look like the thinner stuff but some oil canning is to be expected around the areas where you attach items over it. Also a hydraulic punch works great for making nice clean round holes.
https://lh3.googleusercontent.com/0G...c=w800-h450-no
https://lh3.googleusercontent.com/VH...I=w450-h800-no
https://lh3.googleusercontent.com/YT...=w1608-h904-no
https://lh3.googleusercontent.com/99...l=w800-h450-no
Ed
RV-9A - Down for Panel & Engine Conversion
1946 Piper J-3 Cub - Flying
VAF Donation Paid Feb. 2020
Old 12-08-2018, 10:10 PM
kaweeka kaweeka is offline
Ed,
Pure firewall porn! That looks amazing!!
David
RV-9A N435KR, Vans calendar March 2018
LIO 320 B1A, Dual LS Plasma III, AFP injection
G3x touch
Roseville, Ca
