Old 06-12-2017, 09:23 AM
shadowbrush's Avatar
shadowbrush shadowbrush is offline
Default Dynon Pitot Tube Cutout Drawing
Does anyone have a CAD drawing of the cutout for a Dynon pitot tube? I bought mine from private party and it didn't have the cutout template. Plus, I'm preparing a waterjet cutting job and would like to add a router template for the cutout.
Thanks!
Holger
Old 06-12-2017, 10:37 AM
bruceh's Avatar
bruceh bruceh is offline
The cutout would be for the mast or mount. The Dynon pitot doesn't come with the mount. Safeair and Gretz provide compatible mounts. I used the Safeair mast and it came with the paper template. No need to water jet this. Just drill a couple of holes and use a file or dremel. Ten minute job at most.
Bruce Hill
RV-9A N5771H flown over 700 hours!
2019 VAF donator
EAA Tech Counselor, Build assistance - canopy/tanks/fiberglass/electrical/repairs
Old 06-12-2017, 11:02 AM
Thanks, Bruce. I didn't know the template wasn't supplied with the unit from Dynon.
I know, it's easy enough to hand cut the skin, but I have space on the plate I'm sending to the waterjet shop, so I'd get a free router template out of it. With that, it's a 2-min-can't-mess-up job.
Holger
Old 06-12-2017, 07:07 PM
dynonsupport's Avatar
dynonsupport dynonsupport is offline
Actually, Dynon sells a pitot mount kit now (about a year now) and it comes with a template:
http://dynonstore.com/#!/AOA-Pitot-M...egory=13788255
Here's the template:
http://dynonavionics.com/cgi-bin/yab...ITOT_MOUNT.PDF
_______________________
Dynon Avionics
support@dynonavionics.com
425-402-0433
www.DynonAvionics.com
Old 06-12-2017, 07:14 PM
Thank you, Dynon Support! Good to know. Coincidentally, your pitot tube fit exactly into a hang glider downtube I had laying around, and I'm going to use that. You don't happen to have the template available as PDF, do you?
EDIT Oh, just seeing your link to the PDF - PERFECT! Thank you so much!
Holger
Old 06-12-2017, 07:35 PM
And here is the CAD file, if anyone wants it: http://com.shadowbrush.shared.s3.ama...ube-Cutout.dxf
Holger
