Old 06-01-2019, 01:29 PM
David Paule David Paule is online now
Originally Posted by rcarsey View Post
....Anyone not familiar with [motorgliders], they are basically airplanes with a wing loading of less than .6 lbs/sqft....
Close but not exactly. It's not wing loading based upon area, as the term customarily means, but weight divided by span squared.
For example, at Van's RV-3B gross weight of 1,100 pounds, it would need a wingspan of at least 42.12 feet to be a motorglider.
FAA's actual criteria is 3.0 kg/m^2, or (their conversion) .62 lb/ft^2. It's in AC 21.17-2A, if you're interested.
Old 06-01-2019, 02:48 PM
Default speaking of...
Wish I had the reference handy to verify this, but I don't. According to something I read somewhere (doncha love that?), the FAA has that rule for certifying gliders as gliders, but it doesn't apply to experimentals. So...
Old 06-01-2019, 03:29 PM
I think Sonex uses it to get the Xenos motorglider kits licensed as gliders.
Old 06-01-2019, 03:57 PM
They probably did, but I'm pretty sure they didn't need to. Would the old 'primary glider', the 1st thing Paul Poberezny restored, meet the criteria? I suspect not. If you built one from plans today, would the FAA refuse to license it as an exp. homebuilt glider?
Old 06-01-2019, 05:22 PM
What I was trying to say, is that this:
wouldn't be applied to your homebuilt model 'xyz' glider when you apply for its exp a/w cert as a glider. Which might mean that, for instance, something that looks a lot like an RV-12 (or RV-9), (with a 'friendly' inspector) might conceivably be licensed as a motor glider.
I'll bet that a -9, with just a bit of wing tip tweaking, will out-glide every one of the 'primary gliders' that many learned to fly in back in the 20s & 30s.
https://en.wikipedia.org/wiki/Primary_glider
Paul P.'s primary glider type, at 15-1 glide ratio:
https://en.wikipedia.org/wiki/WACO_Primary_Glider
WW2 troop/cargo glider, at 12-1:
https://en.wikipedia.org/wiki/Waco_CG-4
Old 06-01-2019, 06:35 PM
Actually, that criteria is applied if you're licensing it as a glider. A motorglider is licensed as a glider, I understand. A friend went through this for his Xenos motorglider. The FAA accepted it as the proper criterion.
Old 08-28-2019, 07:12 AM
N208ET N208ET is offline
Default Well
Originally Posted by rv7charlie View Post
There are at least 3 all aluminum 'bushplane' kits I can remember at the moment. The Murphy Super Rebel (now known as a flat engine Moose), the Dream Tundra, and the St Just Cyclone (a Cessna 180 clone).
I didnít state it so my bad, but I was thinking 2 place aircraft. Any 2 place all aluminum bush variants out there?
As stated many times throughout the post, the 2 place bush plane market has a ton of suppliers. With good reason, itís a decent sized market. And those kits require some big money. Obviously the demand is there.
Old 08-28-2019, 11:12 AM
ksauce ksauce is offline
Yes, the Rans S-21.
Kevin
Old 09-10-2019, 07:54 AM
eric.the.blonde eric.the.blonde is offline
My guess is that the RV-15x will be a production -10 built to part 23 performance-based standards.
Lets face it, future growth of Vans Aircraft is not likely to be the result of seducing greater numbers of people into buying kits. I read as much between the lines when they brought the RV-12 in house. Think of the RV-12 as a dress rehearsal for the next big thing.
Van's posted a video on social media showing a rather large CNC punch press (?) type thing being installed earlier this year. Seemed to me to be an awful lot of machine (and a long way from the fabled culture of frugality) for these little kits -- likely has an ulterior purpose.
Eric G.
Ann Arbor, MI
RV-9A under construction (wings)
Old 09-10-2019, 08:16 AM
greghughespdx's Avatar
greghughespdx greghughespdx is offline
Actually, that’s our fourth CNC punch press! It replaced an older one, so we have three on the factory floor now. Those punch machines have been bread-and-butter workhorses in our factory for well more than two decades. The newest one is simply an upgrade in capability and fresh equipment. It enables faster production and allows us to do some punching that the older machines could not do.
Oh, and if we ever got to make a production/certified RV-10 (and I’m not saying that’s going to happen!) we’d probably call it something like the “RV-10.” Just like we did with the SLSA RV-12. New model numbers are generally reserved for new models, rather than production variants.
And, our business has been primarily kits for almost 50 years. It’s worked thus far and sales are quite strong. We don’t intend to move away from kits. Of course, we will move with the times and take advantage of the right opportunities as it fits our business model.
We’re excited about all the things we’re working on! If anyone wants to talk shop, find me at the AOPA fly in this week in Tennessee, or at the Petit Jean fly in coming up in Arkansas in October. Always happy to talk about what we’re up to (except for the top-secret stuff of course, hah) and learn about the airplanes people are building/have built!
Greg Hughes - Van's Aircraft - Community, Media, Marketing
Van's web site | Instagram | Facebook
Opinions, information and comments are my own unless stated otherwise. They do not necessarily represent the direction/opinions of my employer.
Building RV-8A since Sept 2014 (N88VX reserved)
Dual AFS 5600, Avidyne IFD 440, Whirlwind 74RV, Superior XP IO-360
VAF build thread - Flickr photo album - Project Facebook page
Hillsboro, OR (EAA 105)
