Old 09-25-2016, 10:36 PM
mbishop mbishop is offline
Default Pneumatic Squeezer issue
I was working on some test work squeezing rivets, switching yokes out, and die sets looking for the combination that was going to work best when all of a sudden my squeezer stopped pressing the rivets. The head would come up when I triggered it and it would meet the rivet but it wouldn't squeeze it.
I hope this isn't broken and I am doing something stupid.
Help?
2019 Donation made.
Riveting left wing together (RV-10).
Old 09-25-2016, 11:29 PM
If you're squeezing 1/8" rivets, the ram must be near full extension at the end of the squeeze. There's a cam shaped force multiplier inside, & there's more force at the end of its motion.
Don't know if that's it, but it's the 1st thing I'd check. Now, anyway. Ask me why....
Old 09-26-2016, 06:41 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
Charlie is correct. It works best when you have the set holder adjusted so the rivet is squeezed to the proper height and diameter at the end of the stroke. If you don't have an adjustable set holder, get one. They make adjusting, and life, so much easier. And insures more consistent rivet squeezing.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 09-26-2016, 07:01 AM
sibriggs sibriggs is offline
Default Also, check you air pressure.
Steve Briggs. RV9, G3x, G5, VPX, GTN625, PMags, A&P, IA, ATP-CFII
Old 09-26-2016, 12:34 PM
cderk cderk is offline
If you're having problems, read this...
http://www.cleavelandtool.com/instru...leshooting.pdf
RV10 - #41673
http://n688cd.wordpress.com
N688CD Reserved
Old 09-27-2016, 09:29 AM
Being stupid: 1
Broken squeezer: 0
It was the travel of the ram being short.
My first two rivets on this plane.
2019 Donation made.
