Old 06-06-2019, 10:29 AM
GaryK's Avatar
GaryK GaryK is offline
Default Skyview HDX ADS-B Status
I upgraded from the Skyview classics to HDX several months ago with no issues. Flying back to MI from NC Tuesday I noticed my second screen indicated it was receiving (in green) but the RGNL and CONUS were aged in Yellow. My primary screen was also receiving and both RGNL and CONUS were green. Swapping screens and a reboot on my number 2 screen didn't help. I've never seen this before and was wondering if anyone else has. I haven't called Dynon yet.
Gary
Old 06-06-2019, 10:52 AM
Raymo's Avatar
Raymo Raymo is offline
The ADS-B in box is connected to both screens. I suspect you may have a loose connection on the secondary screen.
Ray
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
All lines by TSFlightLines
Old 06-06-2019, 11:27 AM
GaryK's Avatar
Ray,
If it was a loose wire I'm not sure I would be seeing the green receiving indication?
Gary
Old 06-06-2019, 11:58 AM
Raymo's Avatar
Originally Posted by GaryK View Post
Ray,
Gary
Not sure, Gary, but worth confirming. Also check that both screens are using the same RX/TX port numbers.
Ray
Old 06-06-2019, 01:02 PM
GaryK's Avatar
Iíll check the wiring but when flying back I had plenty of time to check the configuration in setup. Also checked the ADS-B page and both screens were showing the same input counters. Meaning they were both counting traffic hits, etc. Both screens also showed ADS-B OK in the lower right corner. They have been working flawlessly for months.
Gary
Old 06-06-2019, 02:01 PM
Raymo's Avatar
That additional information on counters makes it quite perplexing. Next time you fly, be sure to have a USB drive (tested to work) and hit the 2 and 7 buttons to save a screen shot on each. Send those and the logs to Dynon support.
Ray
Old 06-07-2019, 03:48 AM
climberrn climberrn is offline
I have had the same issues with my Skyview Touch screens last few flights. One screen will show conus weather and regional weather outdated but the other screen shows it current. Both show ADSB receiving. It is not always the same screen though. 550 hours on the system. I have the older Dynon ADSB box.
I wonder if it has anything to do with the GPS timing issues addressed in the new update?? Will update as soon as I get home and report back.
Joel
N626JA
RV-7A at CXP
Flying!
Old 06-07-2019, 03:58 AM
paul330 paul330 is offline
See the latest Dynon SB. I suspect this may be the issue ........
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
Building Bearhawk Bravo - RV-18 not available
2019 Donation Made
Old 06-07-2019, 09:23 AM
Raymo's Avatar
SB direct link:
http://www.dynonavionics.com/bulleti...tin_060619.php
Ray
Old 06-07-2019, 10:17 AM
GaryK's Avatar
I plan on updating the S/W this weekend but I'm using the GTN650 GPS signal, not the Skyview . I also don't have an issue with the time or any of the other symptoms associated with the GPS rollover.
Gary
