Old 02-04-2019, 05:55 PM
rocketman1988 rocketman1988 is offline
Default Antennas
Hey all,
Working on mounting antennas and had a couple of questions for the group.
1. I have the Aerosport overhead console. Has anyone had luck mounting a GA-35 or GA-57X antenna between the console and the cabin top? I don't have the antennas in hand but the drawing measurements would indicate that there is insufficient room...Thought I'd ask.
2. Assuming I have to mount the GA-35 on the exterior of the cabin top, anyone have any tips before I drill holes? The cabin top in that area is fairly thick (between the door hinges).
Thanks!
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 02-05-2019, 07:35 AM
mbishop mbishop is offline
Some guy on the RV-10 facebook group was just asking about this
2019 Donation made.
Riveting left wing together (RV-10).
Old 02-05-2019, 08:41 AM
rvdave rvdave is offline
You may have to use a 90 deg fitting but it should fit, mine did.
Dave Ford
Cadillac, Mi
Old 02-05-2019, 09:09 AM
Default Don't think so...
Not sure why...
I only have about 1.5" between the cabin top and the overhead console, at the most.
Looking at the antenna dimensions, I need 1.5" PLUS the 90 degree connector, which is going to be well over 1.5".
Does your installation deform the aluminum panel cover in the overhead console?
Bob
297 HP Barrett Hung
Wiring...
Old 02-05-2019, 07:44 PM
One of the recesses of the two is deeper, true my antenna wouldn’t fit in one but did in the other with a 90 deg connector.
Dave Ford
Cadillac, Mi
Old 02-05-2019, 08:47 PM
DRMA DRMA is offline
If you decide to mount the antennas externally, please be aware that Van's advises against drilling any holes in the RV-10 fiberglass canopy that are not called for in their plans, as the cabin top is a structural element of the aircraft. If you follow this advice, it precludes holes for antennas.
I was able to fit both GPS antennas, plus a com antenna and an ELT antenna on the aluminum tail cone top of my RV-10, while maintaining recommended ground planes and distances between antennas.
I realize there are a number of RV-10s with antennas mounted through the fiberglass top, and as with all things in Experimental aircraft it is up to you as the builder to decide where you want to mount them.
Dave Macdonald
RV-10 Fuselage Moved to Airport Sept 15th for Finishing.
2020 VAF Dues Paid
Old 02-06-2019, 02:36 PM
TomSpencer46 TomSpencer46 is offline
I made a bracket that attached to the rear access cover and used a 90 degree fitting. The top is thinner there and I had enough room. If you want I can send you a picture.
RV-10 N90Vt First flight 11/2/2019
1947 Bonanza 25 years flying Sold
Home field (Spencer) VT09
Old 02-06-2019, 02:57 PM
Default Thanks!
A picture would be great!
I need to mount 2 antennas and comply with Garmin recommendations, so one is going to have to mount forward...
Bob
297 HP Barrett Hung
Wiring...
