XOverZero
OK, Builders...here's a question for you: In assembling the brass terminal fittings to the plastic brake lines, is it an acceptable option to use a heat gun (carefully) to soften the plastic slightly instead of a pan of boiling water? Ref: 27-04.
I do not have the luxury of building at home, and am not at all keen on the idea of having to obtain and use a camp stove or the like in the hangar. Has anyone else done it differently and successfully?
