Since my first engine start I've noticed the plugs in Cylinder #1 are black (sooty) compared to the other 3. I was hoping it was just something that was happening because the first hour or so was mostly idle to 2500RPM. I had the 25 hour inspection done by a Rotax certified mechanic. He said he's never seen it before on only one cylinder. The Rotax response has been not to worry about it as all engine parameters are good and it runs fine.
It may not be connected but I also noticed the exhaust is very sooty. I had a 912 in my Pulsar and never had the issue.
Carbs are balanced
Only run 93 auto fuel (normally 5% ethanol)
Cleaned and re-gapped the plugs
Compression was perfect (25 hour check)
The other plugs are a nice light brown
The plugs are not oily at all, the soot (maybe carbon) wipes off.
Has anyone else seen this issue, if so any suggestions on what else to check.
Gary
Carbs are balanced
Gary
