cactusman
Doing the Rotax S/B purge with the compressor set 10 PSI, the max I seem to get is around 20-21 PSI on the engine page in Skyview after about 30 prop spins....is that right?
Top plugs are removed only...thought I saw someone somewhere saying I should get around 40 PSI.
