WingedFrog
Working on the PAP to check the Pitot and Static lines for leaks, I find a rate of decrease of both speed and altitude about 10 times the minima given in the PAP. I did not put any sealant on the connections of the plastic tubes given the force needed to slide the tubes on the fixtures. I will start sealing all these connections and any recommendation for the choice of sealant is appreciated. Also, is it possible that the procedure described in the PAP is not correct for the Skyview. I read in a posting that per Dynon, one should turn the EFIS off while changing pressure which is not what the PAP is directing us to do. I also noticed that while increasing altitude during the static port test the speed is shooting up. As this is not mentioned in the PAP I am a little concerned but there may be a logical explanation based on the design of the ADAHR.
