I plan to pull my cylinders to replace the pins with the new style pins with integral steel caps. I will pull them just far enough to get the pins out to avoid the ring compressor.
My question is, will I need new rings and a hone? In order to get the pins out, I will need to drag the rings through the rough surface outside the normal travel zone. I am guessing this is done for inspection all the time and I am hoping that those with experience can tell me if I will likely run into problems with oil burning by doing this. I don't want to go through another break-in, but also don't want to end up pulling the jugs a second time to deal with oil burning.
I appreciate your guidance and experience here.
