Daida
Hi there!
Thinking about running the ignition harness from the lower cylinders. I want to put adel clamps on the lowest screw from the valve covers and run the ignition, CHT and EGT wires through. I know it has been done before, just want to confirm that i have to grind of a little bit off the edge of the valve cover to make the adel clamp fit flush.
Pictures will be appreciatet, big time!
Thanks in advance
Daida
Thanks in advance
Daida
