Old 09-09-2018, 10:20 AM
rvator51's Avatar
rvator51 rvator51 is offline
Default Best Paint for inside of cowl?
Any suggestions for what is the best paint to use for painting the inside of the cowling? I have squeeged on a layer of epoxy to seal the fiberglass and am going to use white paint over it followed by foil in the hot areas but not sure what paint works best for this application.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2018 Donation sent.
N53KT RV-6a Flying
N7053L RV-4 Wife's RV (RV4chick's blog)
N56KT RV-4 Finishing
Old 09-09-2018, 10:22 AM
Default Epoxy
I am planning on coloring the epoxy that I squeegee on the cowling...
Seems as if it would do double duty sealing and coloring...
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
290 HP Barrett Hung
Wiring...
Dues Paid 2018,...Thanks DR+
Old 09-09-2018, 10:27 AM
lr172 lr172 is offline
Unless you are looking for cosmetics, you're done. The key issue is sealing the fiberglass and your epoxy did that well. Foil will adhere better to the epoxy than paint.
If you paint, I would go urethane. Rattle can / acrylic paint may not hold up to the heat. I just sprayed the inside of my cowl with a grey epoxy primer.
N64LR
RV-10 in progress
Old 09-09-2018, 10:35 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
I used white epoxy primer so I didn't have to look at the pink color...
White also makes it look brighter and shows up oil spots/leaks better.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-09-2018, 10:57 AM
maniago's Avatar
maniago maniago is offline
You dont need to paint it unless you really want to, tho you do need to do the epoxy step to fill any pinholes, as youve already done. Obviously epoxy primer checks both squares. I used Akzo cause thats what I had, and still have. Then I scuffed it and squeegeed West Marine epoxy over it as I have it left over stuff from fiberglass work and its just going in the garbage otherwise. Dont over think it; you'll see oil stains (and therefore dirt) no matter what you seal it with.
Mani
MustangII (FoldingWing) "Finishing up": IO360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,MiniX,EIS,480,327,240,SL30,Navworx; SteamAlt,AS,VSI,WhiskeyCompass
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Jan2019
Old 09-09-2018, 11:43 AM
pilotkms pilotkms is offline
+1 for white pigment added to the epoxy. Got mine from ACS. $6
Keith
RV 7A RV #9700 May 2017
N325KS the Flying K
Built in SoCal KCCB, now @ KPXE
270+ Hours & 5x cross the USA
2018 OSH - yes
Old 09-09-2018, 12:01 PM
DanH's Avatar
DanH DanH is online now
Finish the inside just like the outside...epoxy seal, epoxy primer, two-part urethane paint. I like white because it shows the location of air and oil leaks.
Sure, nobody sees the inside of the cowl..until you try to sell it. Finishing details make all the difference.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-09-2018, 03:38 PM
woodmanrog's Avatar
woodmanrog woodmanrog is offline
I used Azko heat reflecting paint. Supposedly keeps top surface cooler and is easy to detect maladies.
Old 09-09-2018, 06:42 PM
N941WR's Avatar
N941WR N941WR is offline
I filled the pinholes in the top and bottom cowls with a 50/50 mix of epoxy and acetone. It goes on really thin and I used a 3" wide high nap roller to apply it. It took about four coats (and rollers) but sealed it well.
Then the bottom cowl was completely covered with a thin layer of aluminum contact heat shielding. it has held up well for 11 years.
As for painting the inside, I didn't bother. Nor did I paint my baffles. My thinking was that if I were to have a fire, the fewer paint fumes coming from the engine compartment the better. Truth is, this may never be an issue because I would suspect I couldn't smell the paint fumes over the oil and gas.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-09-2018, 06:46 PM
chrispratt's Avatar
chrispratt chrispratt is offline
Super Moderator
I used the same paint and process - Sherwin Williams Acry Glo -- that I used on the outside. It has held up well for 13 years.
Chris
Chris Pratt (2019 VAF DUES PAID)
RV-8 Flying, 775+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Aero Valley Airport, TX)
