Old 08-15-2018, 12:04 AM
Jermechanic's Avatar
Jermechanic Jermechanic is offline
Default Ellison Throttle Body
My friend has an Ellison throttle body on his 160hp o-320. After 1700hrs of good service he is now having difficulty starting hot.
Has anyone had their Ellison apart for repairs? Apparently their is a replaceable diaphragm that can cause this issue.
As another idea would anyone have an Ellison they would part with. Its a terrible time of the year to have his RV4 out of service
Jeremy
Jeremy Prpich
C-GJZI RV6 Slider
Home base CYYJ- Victoria Int'l
Old 08-15-2018, 04:34 AM
Mark33 Mark33 is offline
I think his best bet would be to send it back in to Ellison for a rebuild. They can be a little hard to reach by email but if you call and leave a message they’ll usually return your call pretty quickly. If you don’t hear back from them just keep trying and you’ll eventually be able to get in touch with them. http://ellison-fluid-systems.com
Old 08-15-2018, 06:46 AM
mvs163 mvs163 is offline
I've had a few Ellisons, not sure how the diaphram would cause a hot start issue only...
I think the diaphragm is a Tillotson (sp) part.
I have a brand new unit if your friend wants to replace, I'm in Canada, no customs/brokerage, shoot me a PM.
Mike
Old 08-15-2018, 07:13 AM
rocketbob's Avatar
rocketbob rocketbob is offline
Unless the diaphragm is torn or if the rubber has gotten hard or stretched, I would not suspect the diaphragm. Otherwise they are easy to replace and at least you can eliminate it when troubleshooting. Tillotson DG-1HD is the part #.
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 08-15-2018, 09:39 AM
Default PM Sent
PM Sent regarding the Ellison throttle body
Mike
Jeremy Prpich
C-GJZI RV6 Slider
Old 08-15-2018, 10:13 AM
JonJay's Avatar
JonJay JonJay is offline
If not already tried, Ellison recommends shutting down with mags, not mixture, for easier hot starts.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 08-20-2018, 08:28 PM
Default Thank you
Thank you for all the responses regarding the 0-320 hot start issue. The problem was being masked by priming while cranking which somewhat helped and mistakenly pointed to the fuel injector.
On further diagnosis a weak/bad impulse coupler was found to be the problem. A replacement Slick mag was installed and the engine starts great now.
~Jeremy
Jeremy Prpich
C-GJZI RV6 Slider
