Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 07-15-2018, 04:23 AM
StarvinRV10 StarvinRV10 is offline
Default Advanced Controls Module vs Vertical Power
Just getting started on my RV 10 build, so I got along ways to go before I need to worry about my avionics, but I do have questions as I'm doing some future thinking. Do both of these products offer the same thing, just that Vertical Power supports Garmin, and Advanced Controls for Dynon and Advanced?
Old 07-15-2018, 07:42 AM
Default Welcome to VAF
Marvin, welcome aboard the good ship VAF
Old 07-15-2018, 10:30 AM
DaveO DaveO is offline
I am not understand you I guess.
I put the Vertical Power Breaker replacement system in my 7A and I used Dynon SVs'. So I do not know the answer to your question about Vertical power only for Garmin, and Advanced only for Dynon and Advanced.
I do not think Vertical Power unit cares what EFIS or type of radios. It is an electronic breaker system and much more as seen on the EFIS.
RV-7A N1243A Sold
#140479 RV-14A N1479B Reserved
Old 07-15-2018, 10:58 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
My quicky view is the the AFS system is more like a Vertical Power and Approach Fast Stack hub combined.
If you want someone else to build the entire panel/avionics for you, it might be the easiest, with simplified wiring due to the "hub" approach.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-15-2018, 05:05 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
These will be available with a complete QUICK PANEL system for the foreseeable future. Hardware/cables etc all in a bundle from Dynon/AFS.
They are more expensive but are in my opinion better. The integration with the Skyview is very nice too!
As someone who does installation work I think they are awesome. Cuts me out of some work though
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 07-15-2018, 07:39 PM
Marvin - perhaps to further clarify some of the comments above...
Vertical Power is about... POWER control. Power in, power out, power switching.
The Advanced Control Module is about all that, PLUS interfacing your EFIS devices, radios and other equipment. The ACM is the "glue logic" that allows one box to talk to the other without you having to do a custom wiring harness from one box to another.
Old 07-16-2018, 07:00 AM
vfr800 vfr800 is offline
Default ECBs?
The Advanced Controls module seems slick, but does it truly offer electronic circuit breaker capabilities (the real benefit of the VPX)?
Would be glad to hear it does, though havent seen that clearly specified. I see what is automotive style fuses but no mention of ECBs.
Having done one RV panel overall with a VPX and fast stack hub system, Id love to see those integrated into an affordable single device!
Ryan M
VAF donation last in Jun 2018
(Exempt but worth it!)
Prior partner in RV-9a & RV-10
Now flying RV-10 #40515
Old 07-16-2018, 08:14 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Yes they do. Dynon page link to the Advanced Control Module with ECB's. Started shipping in March by AFS FB post here.
I currently have a VP-X Pro sitting on the shelf. I'm watching to see what goes on this year (OSH next week and all). Will I stay with the Pro or maybe go with the module. As I understand it the module is not offered as a stand alone product only included with their quick panels. I start wiring in the next few months.
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 07-16-2018, 09:13 AM
Default Good news
Thanks for the clarification, Carlos. Very nice combo unit.
Ryan M
Old 07-16-2018, 09:19 AM
Carl Froehlich's Avatar
Dont overlook the option of not using either product. Im sure they perform as advertised, but lock you into a single architect that may not support your design objectives.
Switches and breakers provide a wide range of design choice.
No flame intended,
