Old 09-08-2018, 05:04 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Originally Posted by Lycosaurus View Post
Installed Russ' o-ring intake kit last weekend. Took it out for a test flight, wow, my vibrations are gone. Manifold pressure at idle is around 10 in/hg. Nice smooth running at low idle. Nice improvement to the plane. Thanks Russ.
Another satisfied customer.
Glad to hear. Thanks for the post Alfio.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 431.1 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 09-09-2018, 04:36 AM
Dustyone Dustyone is offline
Another happy customer,
Installed them last week on the IO-540, easy to do with the help of a 1/4"dve 7/16" Snap-On Uni socket to get the the inside clamp bolts.
As others have reported, install the New SDS collar with the bolts and leave a small gap to simply slip the Viton O-ring and retainer straight in . Torque up the bolts and you are done.
All of my Lycoming retainers were warped and the gaskets were loose in the middle, this engine is only 525hrs SMOH.
Thanks Ross, a great upgrade !
Out with old, in with the new !!
Ashley Miller
RV-10 #40597
Dual SDS CPI
http://www.vansairforce.com/communit...d.php?t=140051
Airflow Systems Air-Con
http://www.vansairforce.com/communit...4&postcount=15
VH-XTE 600hrs +
Redcliffe,Brisbane
Australia
Photos : https://goo.gl/photos/zsfBeVofHMe4ze7i7
Old 09-09-2018, 08:28 AM
rv6ejguy's Avatar
I am glad to here so many people are finding tangible running differences with our setup. Can enjoy flying their RVs more and avoid the frequent gasket changes.
Once I can locate a reliable clamp supplier for the carbed engines, we can get more kits going out the door again. Another batch will be going to anodizing on Monday.
Thanks for the review Ashley.
Old 09-09-2018, 09:42 AM
Toobuilder's Avatar
Found another benefit to these things yesterday. I needed safety the lower baffles and one of the induction tubes was in the way. I tried several times to get a good angle on the problem and then the light bulb went off - just remove the tube! In less than a minute the tube was on the floor and I had access.
In the "old days" we knew tube removal meant some time scraping the remains of the old gasket off the head and then hoping you had a new one around. Not so now.
Michael Robinson
______________
RV-8 - Flying
Old 09-09-2018, 11:24 AM
grubbat's Avatar
grubbat grubbat is offline
Default Clint at Vetterman
On my first set, I tig welded the ends and it looked ok but the angle wasn't perfect. So, I found a set of tuned induction tubes for my "forward -facing-angle-valve-converted-parallel-valve lycoming, and hired Clint at Vetterman to weld them up for me on his jig. Guess what? The welds are beautiful and the alignment is perfect. So, if your welding skills are a little rusty or if you dont have an alignment jig, Clint is the man.
Originally Posted by scsmith View Post
What about the issue that the re-welded pipe is now shorter by roughly the bandsaw kerf width? Assuming you bandsaw cut it, then reassemble by putting the two pieces together, it is now shorter by, what, 0.050" or so.
Does that affect the sealing of the big doughnut seal where the pipe fits into the sump?
I'm guessing the sealing surface in the sump is long enough, (deep enough) that being a little bit shorter doesn't affect the seal? If it is just sealing in a cylindrical bore, that is probably true. If the seal relies on some compression from bottoming in the bore, then the shortened tube would not produce as much seal compression.
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Comanche 260 - poor mans RV-10
Old 11-01-2018, 07:36 AM
rv6ejguy's Avatar
Many of you have been on a list to receive induction flange kits for almost 3 months while we were waiting for our suppliers to ship black silicone hose and constant tension clamps.
We got the hose a few days ago for the injected engines and clamps as well and have been filling back orders for injected engines the last few days. Those are available now.
Unfortunately we received the wrong CS clamps from our supplier in Germany for the carbed engines which use a larger OD hose and still can't fill those orders unless people want to re-use their original screw type clamps.
I'm not happy with the situation after waiting nearly 80 days for these clamps. Trying to find a solution with the supplier today but it could be another long wait as they probably don't have stock and will have to be produced.
I've checked 4 other suppliers/ manufacturers and nobody has any inventory.
Old 11-01-2018, 08:08 AM
grubbat's Avatar
Default O-ring Part Number
Ross,
Do you have the o-ring specs? I need to get a couple of spares.
Cj
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
Old 11-01-2018, 08:48 AM
rv6ejguy's Avatar
They are #135, 70-75 durometer. Silicone for injected engines, Viton for carbed engines.
Old 11-01-2018, 09:06 AM
David Carter David Carter is offline
Default O-ring source
I was able to get extra O-rings locally from Grainger. Their item # 1BYL7 - "Round #135 Medium Hard Viton O-Ring, 1.925" I.D., 2.131"O.D., 10PK" for just over $7. These are 75 durometer Viton for carbed engines.
David
RV-7A Slider N87BP (bought flying in 2018)
2019 Dues Paid
Old 11-02-2018, 05:22 PM
rv6ejguy's Avatar
Default Good News
After hours of searching online I finally found some bulk lengths of fuel approved, made in USA, Buna-N reinforced hose with the correct ID and OD so we can use the same clamps on carbed and injected engines now. I have a couple lengths in hand now and can start filling back orders for those on the "list" with carbed engines this weekend until we run out of flanges.
More flanges are being CNC'd this weekend as well and will be off to anodizing on Monday. Colors available will be red, gold and clear.
