Old 05-30-2018, 12:00 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
The other advantages are they won't leak and the bolts won't come loose since there is complete metal to metal contact between cover, cylinder and fastener.
Should be higher heat transfer from the oil to cover being aluminum instead of steel but unless you had a lot of air blowing over them, doubtful that would be significant in reducing oil temps on a fully cowled engine.
Can have custom colors and logos for those who want to dress up or customize their engine.
I believe they are less expensive than the factory chromed covers.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 431.1 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 06-02-2018, 10:33 AM
rv6ejguy's Avatar
I have all the parts back now for the first 4 pre-production covers. Weight for each VC with gasket and hardware is 242 grams, the production ones measure in at 292 grams.
Old 08-21-2018, 10:57 AM
Noah's Avatar
Noah Noah is online now
Originally Posted by rv6ejguy View Post
Stock steel cover with standard thick silicone gasket is 238 grams.
Do I have this right, your production aluminum units are coming in at 292 grams, or 54 grams heavier, than the lycoming stock steel (238 grams), per cylinder?
There is complete metal to metal contact between cover, cylinder and fastener.
Are you saying that the gasket's preload is set when the fasteners are torqued and you have metal-to metal contact? And that the preload is not a user-adjustable parameter like it is with the steel stock units? (I like that)
Am I correct in assuming your covers are not compatible with Real Gasket Corp's silicone gaskets?
http://www.aircraftspruce.com/catalo.../lycgasket.php
And finally, what is the cost?
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous menů for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
Old 08-21-2018, 12:34 PM
rv6ejguy's Avatar
I think you may not have measured the stock one with gasket and hardware.
Correct, you can smoke down the fasteners and gasket compression is always the same. The VC makes metal to metal contact with the head.
You must use our gaskets. Our VCs are not compatible with any other gasket types or brands. We supply 2 sets with each cover order and will sell replacements at below the cost of other aftermarket silicone gasket suppliers.
Old 08-21-2018, 02:48 PM
If there was a supplier that I was dependent upon I would be OK with it being Ross. It's pretty hard to beat his commitment to customer satisfaction.
Old 08-21-2018, 09:08 PM
Mjuckes Mjuckes is offline
Thumbs up Agreed
What Mark says. ^^^^^
RV-4 flying
F1 Rocket
Old 08-22-2018, 06:42 AM
rv6ejguy's Avatar
We appreciate the kind words!
I see I missed a previous question on cost. It looks like they will be $115US ea anodized in red, gold, black or clear with hardware and 2 gaskets per cover.
Old 09-11-2018, 04:54 PM
rv6ejguy's Avatar
Default Production covers finally in hand
I received the first batch of production angle valve covers today so can start filling orders when I return from Reno. I'll be contacting those who are on the "list" to get color choices finalized.
Here is the first full look at the sealing system.
Full set of parts for one cylinder with stainless socket head cap screws, AN washers and custom silicone gasket. 2 Gaskets will be provided per cover.
Raised spigots ensure consistent gasket compression while fasteners can be fully torqued down.
