Old 07-31-2018, 05:33 PM
f14av8r's Avatar
f14av8r f14av8r is offline
Originally Posted by FasGlas View Post
Haha.. Experts = BS.. They are all biased. They either work from a company or they believe they are important. As far as MMO? I've seen it work. Years ago I had a Turbo Arrow with a low cylinder, added 1/2 qt MMO and the compression came up within a few hours F/T. I've seen MMO loosen a frozen Briggs & Stratton. Story after story from friends and pilots about MMO working magic. The mystery is why people like you only believe "Experts" that have a stake only in their product. I'm sure you have no idea the history of MMO. Might want to look that up.
Not only do ALL the oil companies and the additive companies have their own "Test Labs" but they ALL test so their products produce the results they want. Change the temps, change the pressures, change the weight, change anything they want to say what they want. The only requirements of oil is that it must pass SAE standards, nothing more. Anyone remember when the audio companies stopped using Output Watts RMS to state the power output of an amplifier? The wild output claims that every audio company made after that was a joke. Don't be so gullible.
Now don't go gettin your panties in a wad. I was just passing along what I heard in the lectures. I'm still trying to form an opinion which is why I asked the question. If you think MMO is the cat's meow, I value that feedback. Nobody else seems to think so but, if it worked for you, I appreciate your offering your experience.
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (flying)
Flying an A320 to pay the bills
Exempt and gladly donating anyway - Current through March 2020
Old 07-31-2018, 06:19 PM
jbDC9 jbDC9 is offline
There are others that use and appreciate MMO; a few years ago I had a stuck exhaust valve. The crusty, err, experienced mechanic that fixed it recommended that I run MMO in the gas to help keep the valves and stems clean; it seems to be working for me so far. I also see many radial engine Warbird types doing the same... itís gotta be the lovely wintergreen scent thatís the effective ingredient here.
John Bixby
RV-8 QB sn 82030 - 1575 hrs
O-360-A1D/CS/Pmags
Houston, TX
VAF donation Dec 2018
Old 07-31-2018, 07:39 PM
FasGlas's Avatar
FasGlas FasGlas is offline
I'm an A&P, just getting ready to test for IA. I know plenty of A&P's and IA's, every one of them recommend using MMO. The military kept tons of 55 gal barrels of MMO at all the airfields. Note: Does the name Marvel ring any bells? How about Marvel Shreiber? A whole lot of you guys are flying with one. Yes, he invented Marvel Mystery Oil... Very interesting story. 100's of 1000's of military pilots and mechanics all agree MMO worked. Sorry, I don't blindly follow the "Experts".
Old 08-01-2018, 07:29 AM
Just a quick comment / observation. When I last took an engine in for overhaul the shop disassembled the engine right in front of me so I could have a good close look at its status and a much better idea of what the overhaul was going to cost.
When the engine had been torn down I noticed gold-coloured deposits in the engine. Sort of like the appearance of the foil insulation in airliners before smoking was banned - a gold haze over everything. The overhaul shop manager asked me if I ran AeroShell oil. Of course I did!
He then showed me an engine in a similar state of tear down, and its interior metal surfaces were shiny silver metal like a new engine. That engine had gone to TBO running Phillips XC 20W50.
When it came time to spark up our brand new Lycoming O-360-A1F6 I remembered those gold deposits in the engine and started the break-in process using Phillips XC 20W50, and continue to run it today. Break-in was uneventful, despite frigid winter temperatures. Oil consumption now is about a quart in 20 (or more) hours, and the filter remains clean of any debris.
I know precious little about petroleum products so that little side-by-side comparison of an engine that had run AeroShell and an engine that had run Phillips was an education for me.
Old 08-01-2018, 08:28 AM
uk_figs's Avatar
uk_figs uk_figs is offline
Default getting a headache
Interesting thread, I followed ECI's guidance for my 0-360 break-in and have run Phillips XC 20/50 ever since with the addition of camguard and some MMO in the gas. The oil sample analysis from Blackstone can be summarized as "keep doing what you are doing".
I guess the question for us non experts is what would we keep our eye open for to suggest the need to change an approach that seems to work?
Figs
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
Old 08-01-2018, 11:05 AM
DanH's Avatar
DanH DanH is offline
He then showed me an engine in a similar state of tear down, and its interior metal surfaces were shiny silver metal like a new engine. That engine had gone to TBO running Phillips XC 20.
Which Aeroshell, and why is gold coloration bad? Any component damage or excess wear?
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-01-2018, 11:33 AM
6 Gun 6 Gun is offline
Cool TBO
CJ did your engine go to TBO also?
Bob
Old 08-01-2018, 12:26 PM
skylor's Avatar
skylor skylor is offline
Default MMO
I don't recall seeing this before, but those considering using MMO might want to at least read this NTSB report:
https://www.ntsb.gov/_layouts/ntsb.a...16X01610&key=1
Skylor
Old 08-01-2018, 12:40 PM
Skylor
You might want to read a *lot* more NTSB reports, for some perspective, before attaching any real significance to this one. 1st it wasn't an airliner. 2nd, well, it wasn't an airliner. Reservoir of expertise: Exhausted.
Inevitable conclusion as to cause: Whatever (or the 1st thing noticed, that) was unfamiliar to the examiner.
Charlie
edit: I suppose I should add a ;-)
Old 08-01-2018, 01:01 PM
uk_figs's Avatar
Default NTSB report
Interesting conclusion reached based on what is written:
1) Tanks were all full
2) No mention of which tank was feeding the engine at loss of power
3) No mention of the actual ratio in the MMO tank
4) Low compression and leaking valves in all cylinders and evidence of detonation but no analysis of MMO being the cause of any of those symptoms
5) Net result was MMO caused the problem??????
Dave's RV-7 Blog
Email me
