I have always been a big fan of wing root disconnects for electrical lines because, well?..I like being able to disconnect everything if I am going to disconnect something. I have never really encouraged anyone else to put disconnects at the wing root, staying out of the advice game ? but it just seems cool that if you are going to pull a wing, you can disconnect the wires right there with a dedicated D-Sub, Amp, or Canon Plug. Many have just said ?put an extra service loop of wire in there, and if you have to pull a wing, cut it and splice the wires back together later.? Well,?.that just seems so messy ? and if the disconnect doesn?t do any harm, well, why not trick it out?
Well, I am done with that. I hung the wings on the RV-8 ten years ago ? they have never had to come off. The RV-3 wings went on in 2011 ? same thing. Mikey, the RV-6?.I think the last person to see it with the wings off was Mike Seager when he built it, and that was over 25 years ago. The wings just don?t have to come off on these things. And on the side of ?disconnects don?t do any harm?, we spent the better part of a day tracing a flaky OAT signal on the RV-3 last week ? and much of that was trying to work on the disconnect through the wing root fairing. Sure enough, there was the problem, a pin/socket that had built up a little schmutz (or something). There is no room on an RV-3 to get your hand in there without pulling a wing ? and we sure weren?t going to do that! Louise finally got her smaller hands in that way, and I went under the seat pan (which is riveted in, so it was actually back under the inspection covers and then under the pan) to get it working. If I?d just had a loop of wire ? there wouldn?t have been a problem in the first place.
So yup ? I am done with wing root disconnects. Well, except for the motorglider, we might want those wings to come off. And then the Tundra we?re working on?.not sure how our partner did those when he hung the wings?.but from now on, for me it?s just a loop of wire, no extra connections to fail, and if the wings come off, out come the cutters and the splices when they go back on.
Sort of like nutplates and the rear floors on the RV-8 ? its? quicker to drill out the pop rivets if it ever needs to come out than to unscrew all the screws and mount all those nutplates?..
Paul
Paul
