azcloudflyer
I am installing the MATCO nose wheel axle and have a question on bearing preload. The instruction say to tighten until the bearing grease seal is stationary to the axle and does not rotate with the tire. I have gone as far as I can go hand tightening, one of the seals still follows the wheel a little and the wheel is hard to turn on the axle. Should I try to go tighter using tools? Was your nose wheel hard to turn after tightening the axle nut?
