Newer member here. If this is already clearly covered in another thread, I apologize. I've been reading so many conflicting and unclear posts, blogs, and articles my head is spinning.
1. Originally, I thought in a Rotax 912 ULS I was going to have to run "Clear" - non-ethanol, high octane gas. After reading many things, including info right from Rotax, I now believe I can safely use AKI 91 w/ 10% ethanol. Is this correct?
2. Again, from reading many conflicting articles/postings, I am confused about the proper container to use in humping fuel to the airport: plastic vs. metal. I've read that the action of pouring gas through plastic creates static buildup that can jump to the fuel/air mixture when entering the plane. I've read that metal is safest and yet most pictures/videos/and even ads have plastic jugs being used.
3. Bonding: I cannot find any picture or video of someone demonstrating bonding their portable gas can to the plane. My CFI doesn't bother; he just pours directly from the plastic 5 gallon container into the plane.
4. Do most RV-12 owners recommend using Mr. Funnel, and if so, which model.
Thanks in advance! Jim
