There are prior threads on this, but they all seem to resolve without a final answer.
I am on 14-04 at the stage where I have to start drilling for the snap bushings in the wing ribs.
Clearly if you follow the text of what they are asking you to do you end up drilling lots of holes which apparently are not used later on at all, and lack snap bushing callouts. Examples of this are the left wing, 4,5,6 ribs counting from the outboard side.
I have seen the master list of errors. Ken at Vans told me most likely they have this written this way so all the ribs are the same even if you don't use the holes you drilled. So my question for everyone who has done this already, is:
Did you end up looking ahead to Chapter 19 and just drilling the holes which were used, or did you follow the instructions here and drill out extra holes including using the sizes that they are calling for in the plans so that you can use the snap bushings provided?
Thanks.
Thanks.
