I purchased the copper buss bar stock from Van's which is .063" thick x .5" wide with the notion of making buss bar connections between the battery lug and starter solenoid on the firewall. The lugs are 5/16" in diameter which leaves about 3/32" on either side left in the buss bar. Do typical edge distances apply here? Is this acceptable? I would think it OK simply because there should be no movement or vibration between the battery lug and starter solenoid at all. It's a fairly important connection though and one not intended to fail mechanically.
If I wanted to purchase wider material where does one usually find it?
Is this acceptable... thoughts?
