Garmin GTX 345 with GTN 650 ADS-B Performance Report Fail
jliltd
We have a GTX 345 ADS-B out/in transponder and a GTN 650 navigator. We tried for our rebate yesterday but got an exception with respect to the NIC variable. Here are some pages from the performance report:
index.php
index.php
index.php
http://flyhusky.com/forum/index.php?media/performance-report-adsb_page_4.2106/full
I am not sure what that means but we had the INTGRTY setting on "Auto" which equates to a Garmin GPS source. I bring this up as we are considering setting INTGRTY to "IE-7", which is the default Garmin value.
Does anybody have any insight into this NIC failure?
Jim
I imagine setting it to IE7 which is for garmin certified sources would fix the problem. Below is a quote from AC 20-165 concerning the NIC parameter.
"A minimum NIC value of seven must be transmitted to operate in
airspace defined in 14 CFR ? 91.225"
airspace defined in 14 CFR § 91.225"
His average NIC is 8.9 :)
I could read the report as saying that you had a 13 second drop out when the NIC was being transmitted at less than 7.
This 13 second timing would be around the 0.61% error mentioned in the report. Perhaps your GTN650 had a 13 second drop out and wasn't giving data to the GTX?
However, setting the INTEGRITY to 1E7 via the front panel would probably be a good thing. :)
index.php
index.php
index.php
Jim
Hello Jim,
Were you maneuvering agressively on this flight?
We see a lot of reports, and it is unusual to see a NIC error like this, but that is a pretty clean report with less than 1% non-compliant output in only one parameter.
No harm in changing the Position Integrity to 1E-7, but I don't think that will change anything.
I would make another flight and request another report before being concerned.
If you continue to see issues like this, I would look at the GTN antenna installation.
Steve
Hello Jim,
Were you doing any maneuvering on this flight?
Steve
I hope he was maneuvering if he wants the $500 rebate...:D
https://www.aopa.org/news-and-media...ts-seeking-ads-b-rebates-some-steps-clarified
