Hi All,
New builder here. The attached picture is the R-904 bottom rib. It is sandwiched between the rudder horn and rudder spar. I am concerned about 2 things:
1. The large hole for the Rudder rod end is way to close to the edge. I dont know of this is an issue as the rod end is not a fastener.
2. The rivet holes seem to be a bit oblong. Is this a problem?
Any thoughts would be great!
