RV-10 PAGE 11-10
STEP 3
"Step 3: Thread the E-616PP Cover Plate - Elevator Trim/ WD-415 Elevator Trim Cable Anchor Bracket Sub- Assemblies on to the CT Q-43 Elevator Trim Cables. Adjust so that the elevator trim cable anchor brackets are centered on the 7/16 threaded portion of the elevator trim cable anchor points. Attach the cover plates to the bottoms of the elevators."
Was able to get the left one on but I don't have enough clearance on the right one to thread the nut and attached plate around the cable. The cable is shorter on the right side due to the geometry of the system. Seems like drilling the rivets and removing the nut, threading it on and then re-riveting the plate back onto the nut may be the easiest approach. Suggestions??
STEP 3
