az_gila
Flap bearing attachment question
RV-6 only - the RV-7s and up are different.
The Aurora CM-4MS "stud end bearing" at the flap end of the flap pushrod has a threaded portion that is 0.562 inches long.
I can't find the hardware callout for the nut on the stud, but I followed standard practice and used an AN365 nut and AN960 washer.
BUT
Material thickness (1/16 + 1/8) = 0.188
AN365 nut height = 0.312 to 0.328
AN960 washer = 0.063
This all adds up to 0.563 to 0.579 + a little extra for 4 layers of primer.
Not even a single thread showing above the nut. I can change to a thin AN960L washer but even that isn't really enough.
What did other builders do here?
Use no washer?
Use a thin AN364 shear nut? - but this does seem like a high stress location
Or switch to a MS21042 nut which is only 0.219 high?
BUT
Use no washer?
