Old 08-19-2019, 09:47 PM
AirHound AirHound is offline
Question 912uls Floats
Are the blue floats being redesigned to be 6 ounces or no change in the near future?
Doug
Old 08-20-2019, 09:20 AM
DaleB's Avatar
DaleB DaleB is offline
I don't quite understand the persistence of the question about whether they would be made to exactly match the weight of the old floats. The weight of the floats is immaterial. If the floats weigh more, it's fine -- as long as the manufacturer correctly designed them for the correct displacement and the placement of the pin. The old floats have a maximum weight based on their exact size, density, and where the pin is located. Floats made with a slightly different size, shape, material, etc. can have a different weight and still function the same.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 08-20-2019, 11:13 AM
So no problem to use current production?
Doug
Old 08-20-2019, 11:31 AM
DaleB's Avatar
I have no idea. I'm still using the original floats. Maybe ask the manufacturer, which inexplicably no one seems to have done. I'm sure they could answer the question.
Dale
Omaha, NE
