Old 08-19-2019, 04:34 PM
Davea320 Davea320 is offline
Default Electronic Ignition: Two alternators or two batteries
Looking for electrical power and backup for electronic ignition and I am asking for the pros and cons of a two battery system with one alternator or a two alternator system with one battery. Thoughts?
RV7 QB started 1/17
Working on finish kit
2019 dues sent
Old 08-19-2019, 04:42 PM
bkervaski's Avatar
Which electronic ignition?
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 08-19-2019, 05:09 PM
Bavafa Bavafa is offline
Based on my personal choice and safety assurance;
Two alternator, one main alternator that runs/supports the whole ship's power and one that is built-in to the EI and works a self generating EI.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 08-19-2019, 05:11 PM
N546RV's Avatar
N546RV N546RV is offline
I'm planning on an SDS CPI2 ignition. My intent is to have two alternators, as well as the integrated backup battery solution offered with the CPI2. I'm leaning towards the two-alternator system because, to me, it offers fewer concerns in the case of a primary alternator failure. That is, rather than needing to worry about battery capacity, I can effectively fly indefinitely. If I have both alternators fail, then the backup battery will give me enough juice to get on the ground.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
https://www.meetup.com/Houston-Area-RV-Enthusiasts/
Old 08-19-2019, 05:25 PM
scard's Avatar
scard scard is offline
I wonder how many of us have actually used that second alternator that we haul around 100% of the time. I have. It allowed us to continue a week long trip without a care in the world until we got home. ONCE. We're all different, and I've gone back and forth, but I think that one use, saving our vacation enjoyment, was worth it to haul around the ballast for the last 12yrs. Hmm, or was it. A personal choice that the math can't always support.
I've also failed both at the same time in a distant foreign country across a big body of water... (which we won't talk about).
Scott Card
CQ Headset by Card Machine Works
RV-9A N4822C flying 2200+hrs. / Cedar Park, TX
Old 08-19-2019, 05:33 PM
N941WR's Avatar
N941WR N941WR is offline
Install two P-mags and you will not have to ask because you won't need either.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-19-2019, 05:49 PM
Bevan Bevan is offline
It’s good to define what each is best suited for. You need at least one of each, but for a third supply of electrons, which form of supply should it be?
A) Batteries are a short term reservoir of electrical power with decreasing capacity over time, capable of high loads for a short period of time, and topped up by the alternator.
B) Alternators are a constant supply of electrical energy good for supplying some/all constant loads and recharging the battery (reservoir).
Choosing one or the other involves considering failure modes of components and of the electrical system in general.
I have 2 Pmags (they self generate electrical power) one lithium battery, one main alternator, one smaller standby alternator. That makes 4 alternators total and one battery, which is easily changed during routine maintenance. To each their own but these are my choices.
Bevan
RV7A Flying
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 08-19-2019, 05:55 PM
DanH's Avatar
DanH DanH is offline
Do those alternators work well with the battery disconnected?
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-19-2019, 06:45 PM
tracy tracy is offline
One battery, one alternator, one electronic ignition, and one engine. A manís man.
Tracy Willingham
RV-8
Powered Paraglider
Pitts S2B- sold
Chattanooga, Tn
Dues Paid
Old 08-19-2019, 07:03 PM
Thanks for all the quick replies. Leaning towards two alternators and one battery.
RV7 QB started 1/17
2019 dues sent
