Old 08-12-2019, 11:10 AM
Tacco Tacco is offline
Default Vibrating Flap Handle
Today on approach my flap handle began vibrating noticeably. 60kts and full flaps. No vibration through the stick at all. Went away on final. When I say noticeable it was vibrating against my leg significantly. I’d say the end end (button) was displacing plus and minus 1/8 - 1/4 laterally. What the heck!
Steve Morrow
RV-12 N12SM
Builder 121036
White Salmon, WA
2019 Donation Paid
Old 08-12-2019, 11:13 AM
DaleB's Avatar
DaleB DaleB is offline
That is indeed odd, and I'd want to figure out the reason before further flight. There was an SB for inspecting the flaperon bearing bracket. Have you done that inspection?
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 08-12-2019, 12:48 PM
There is also a Safety Alert on early flaperon actuator arms with incomplete welds.
Old 08-12-2019, 01:55 PM
Yes, very odd. What makes it really odd is that there was no stick vibration. I don’t think it was a control surface problem or a issue with the brackets and pushrods. And yes I complied with the SB. Upon landing, the handle doesn’t appear loose. Could it be that I just hit some kind of resonant vibration frequency of the flap handle itself? I wouldn’t even know how to troubleshoot this one.
Steve Morrow
RV-12 N12SM
Builder 121036
White Salmon, WA
2019 Donation Paid
Old 08-12-2019, 03:22 PM
rv9builder rv9builder is offline
That would be my guess. I had a similar issue in a Piper Warrior that I owned. On short final, at a certain rpm under certain conditions, the door handle would suddenly come alive and start vibrating like crazy! It would only happen occasionally, but when it did, it was loud enough to be quite startling. I tried to track down what was causing it, but was unsuccessful.
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2019
Old 08-12-2019, 09:02 PM
Pretty much determined I need to dynamically balance the prop. Anyone know where to rent a Dynavibe?
Steve Morrow
RV-12 N12SM
Builder 121036
White Salmon, WA
2019 Donation Paid
Old 08-12-2019, 11:50 PM
Hal-san Hal-san is offline
Steve, I don't know where white Salmon is but the EAA chapter in Puyallup does dynamic prop balances for $50.00 if you are a member of EAA.
Harold Irvine
N912HM RV-12 Flying.
