Old 08-19-2019, 12:14 PM
rapid_ascent rapid_ascent is offline
I’ve been reading about the manifold plumbing. What route did you take? Im thinking of just using some barb fittings with the silicon tubing running over the the spare spot on the sensor manifold block.
Ray Tonks
2020 Donation Paid
Titan IOX-370 on order
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
Shop Setup - In Progress (Gathering Tools, Never Complete)
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 08-19-2019, 12:23 PM
bkervaski's Avatar
I did the manifold pressure plumbing this morning using the kit from Aircraft Specialty, they have it all figured out, no guessing. They send everything needed, even the small stuff, highly recommended.
I'll take some pics when it's done ... getting close! (I spend a lot of time getting wire routing the way I like it)
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 08-19-2019, 03:27 PM
AltonD's Avatar
AltonD AltonD is offline
I had a noise issue with my install. The Tach was reading way high. I put the diode in at AFS recommendation (12 v system), this helped. Ultimate cause: I use a shielded wire for the tach signal. I grounded the shield at each end. bad no-no. Cut the ground on the engine side and all was well.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
“The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.”
Mark Twain
Old 08-19-2019, 03:31 PM
bkervaski's Avatar
Thanks!
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 08-19-2019, 03:34 PM
AltonD's Avatar
Originally Posted by bkervaski View Post
I did the manifold pressure plumbing this morning using the kit from Aircraft Specialty, they have it all figured out, no guessing. They send everything needed, even the small stuff, highly recommended. . . .
They made up the manifold fittings/hoses for me as well. works great.
For timing, I pull off the two black hoses and plug into a autozone tee with hose to time both mags at once.
Alton DeWeese
N4IDH
Construction Log
Mark Twain
Old 08-19-2019, 06:48 PM
Northernliving Northernliving is offline
Wondering if anyone has integrated pmag information into their Dynon Skyview system. If so, any PIREPS?
https://forum.flydynon.com/threads/p...h-dynon.12236/
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 08-19-2019, 07:01 PM
Mark Dickens's Avatar
I've been running PMags for almost 3 years using black silicone tubing and nylon fittings (from McMaster-Carr) for the plumbing, so I'd be curious to see how your setup looks.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 08-19-2019, 07:10 PM
AltonD's Avatar
No pic at this time. Hangar is a 20 minutes away.
basically, braided hose with a straight piece in the middle with two connections for the two black hoses from the pmags.
one end of the braided hose goes to the #3 cylinder, the other goes to a firewall fitting for the manifold transducer which is on the cockpit side of the firewall.
Pretty simple installation, no idea what I paid for it.
Alton DeWeese
N4IDH
Construction Log
Mark Twain
Old 08-19-2019, 08:41 PM
azflyer21 azflyer21 is offline
Starting on pg. 5 you can see the PMag install from the ASF manual http://www.aircraftspecialty.com/PDF...RV-14%20FF.pdf
Kevin Lippert
Zenith 750 completed 2016 -
Sold
N1402 reserved
RV-14a Empennage Done
QB Wing QB Fuse inprogress
Build Log
New Build Log
Old 08-19-2019, 08:42 PM
Kevin Lippert
Sold
N1402 reserved
Build Log
New Build Log
