Go Back   VAF Forums > The Never Ending Debate Section > Tools
Old 06-23-2019, 06:09 PM
knievel knievel is offline
Default Who makes a close quarters pop riveter@
The title says it all. I need to put some pop rivets in the center flange of my horizontal stabilizer. The riveter i borrowed from work has far too broad a head.
Anyone know where I can buy one that fits?
RV-8 Empennage started
Old 06-23-2019, 06:16 PM
Kyle Boatright Kyle Boatright is online now
Section 5 (IIRC) of the build manual tells you how to fabricate an off-axis pop rivet assistance tool.
Another approach is to buy a cheap pop rivet tool and grind the nose to match your needs.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 06-23-2019, 07:03 PM
catmandu's Avatar
catmandu catmandu is offline
I have used both these options with good success, after a little bit of practice to refine the technique.
Mike C.
Sierra Nevada
RV-6A bought flying
Old 06-23-2019, 08:01 PM
rv9builder rv9builder is offline
This tool has worked well for me:
Cleaveland Tool Close Quarter Rivet Pulling Wedge
http://www.cleavelandtool.com/Close-.../#.XRAgDy3MxE4
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2019
Old 06-24-2019, 07:09 AM
KayS KayS is online now
I grinded off a "not-cheap" pop rivet tool. And after years and countless following pop rivets it still works perfect.
Old 06-26-2019, 02:13 AM
Bevan Bevan is offline
I ground a cheap pop rivet tool for close quarters. It works better than my more expensive tool so itís been my go to all purpose riveter.
Bevan
RV7A Flying
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 06-26-2019, 07:06 AM
mturnerb mturnerb is offline
One of my most favoritist tools.... (please don't correct my spelling, it's intentional!)
Turner Billingsley
RV-14A FLYING, N14VB
Old 06-26-2019, 08:08 AM
MED MED is offline
I think you meant "mostest favoritist". . .
MED
140236
N435MD
Miss March 2020
Old 06-26-2019, 08:26 PM
We need like buttons here....
Turner Billingsley
Old 06-26-2019, 10:38 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
The professional (expensive) tool would be something like a GageBilt GBP704E-Cherry Max riveter with the Cherry offset pulling head.
You may be lucky and get that combo on EBay for about $600 (but you could always sell it again afterwards for the same amount).
That said, I've used the methods described above with some success and also had to drill a few out again when the plug didn't pull through.
It's quite easy to make the pulling wedge described above from 3/8" square steel bar. I have a drawing somewhere that I could send if required (edit: drawing added).
http://forum.cubcrafters.com/attachm...5&d=1323101512
