Old 05-08-2019, 12:56 AM
jtate747 jtate747 is offline
Question Carb/Air filter clearance
(I am building an RV-6A. I have an O-360 out of a Mooney with 60 hours on it installed. Unfortunately, the air filter box is contacting the nose gear. There are many variables that can cause this, so I am wondering if ....
- The oil sump is deeper than normal for an RV? How deep is the normal sump?
- The Carb is taller than another standard configuration (6.5 inches from oil sump to base of carb)
- Other ideas?
Also, the engine is offset to the left about an inch, but I understand this may be normal.
Is there a shorter carb option? Smaller air filter?
The air filter box actually contacts the nose strut. I have not installed it yet.
John
Old 05-08-2019, 05:10 AM
noelf noelf is offline
I had the same issue when I built my -6A. I cut off the offending area from the fiberglass FAB and glassed in the area to clear the nose gear strut. I also had some issues with the bottom left side of the FAB contacting the cowling carb air inlet side and had to bevel the FAB to clear this area also.
Noel
RV-6A N6NF
tip-up
flying
Old 05-08-2019, 09:53 AM
az_gila's Avatar
az_gila az_gila is offline
I made a small "bump in" where the nose gear is and also made a new mounting plate that took care of the offset and moved the FAB box a little further forward.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-08-2019, 02:03 PM
WingsOnWheels WingsOnWheels is offline
I had a similar problem, but was able to make a new top plate and get it far enough away. Still requires that the nose gear fairing is modified.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
I donate every year on my B-Day (in Dec), but donated early in Sep'19.
Old 05-09-2019, 08:05 PM
Thanks Gentlemen,
I will probably need to do a combo of the ideas above to make it work. Just making sure I am on the right path, before I start changing proven designs. Just seemed odd to me that “My” O-360 carb is lower than all the others ever built . . . .
Thanks!
