Old 04-22-2019, 02:04 PM
Driving '67 Driving '67 is offline
Default Heater Knob on Wiring channel faceplate
Hi,
Iím thinking of moving my heater controls to the wiring channel faceplate below the instrument panel to free up some space. Has anyone done this? Pictures and suggestions on your install would be much appreciated
Thanks Jim
RV 14A wing/tail/fuselage done
Canopy time
Serial 140118
Donation 2018/19
Old 04-26-2019, 06:54 PM
Jake14 Jake14 is offline
nt sure which wiring channel you mean, but in all designs I've seen, heater knobs are reachable without unfastening or loosening your seat belts
RV-14A #140158 flying
Old 04-27-2019, 04:19 AM
mturnerb mturnerb is offline
Given the standard location at the lower outside corners of the panel, how much space could you gain by moving them? The standard openings are pretty "out of the way" as it is, and the structure under the panel in these locations limits access for anything else. The cables aren't in the way of anything, so not sure I understand how much could be gained for the effort involved.
As far as relocating to the wiring channel faceplate, this is already the home to throttle/prop/mixture/alt air AND the channel behind this is used (in my airplane anyway) to route wires across underneath (Van's provides those nice holes for cable ties to make this easier) so it would get a bit crowded.
Turner Billingsley
RV-14A FLYING, N14VB
Old 04-27-2019, 05:42 AM
Just thinking out loud. Looking at installing a park brake and trying to find a logical position that doesnít interfere or crowd other components.
Canopy time
Serial 140118
Donation 2018/19
Old 04-27-2019, 08:22 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
On my RVs I mount the parking brake valve under the panel. With a reach it is easy to operate the lever arm, and does not require a separate actuator cable and such.
Old 06-08-2019, 10:07 PM
JDA_BTR JDA_BTR is offline
I mounted my parking brake pull on the left where the left heater control would usually go. Stein fabricated a wide plate for mounting the throttle/prop/mixture that incorporated a left pull hole for my heater and a right pull hole for my AltAir. The passenger heater knob is in the usual right spot.
So my left side is the brake - can be released outside the plane easily.
Right side (just to left of throttle) is my heat
Far right (just to right of mixture) is my Alt Air (don't touch...)
Passenger right is their heat.
SteinAir provided the painted and labeled control knob panel when they provided the other panel items.
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 06-09-2019, 07:58 PM
Any chance you could post a pic of your setup.
Thanks Jim
Canopy time
Serial 140118
Donation 2018/19
