Old 04-03-2019, 08:19 AM
Megs4sale Megs4sale is offline
Default New 14A kit owner
Took deliver last week of a new Qb fuselage and wings from Vans. Bought my new friend Dave Oakes’ -tail cone assembled along with balance of the project needs and tools. Great guy btw!!! Anyway, after removing the fuselage from the crate, it caught my eye that the trigear slots were not missing. Contacted Vans thinking I got a -14 kit but learned they all ship that way and the owner does the mods to convert. Seems like it will not be easy to finesse the cutouts given the tight space. Searched forum and didn’t see any direct tips. Any recommendations on method/tool? Inventoried, organized and ready to plunge in.
Any recommendation on when to marry the tail and fuse?
Don Mosier
RV-14A build in progress
Cubcrafters
Old 04-03-2019, 09:11 AM
azflyer21 azflyer21 is offline
I used a step drill bit to drill several holes, then nippers to remove the remaining material, and plenty of filing. You also have to drill the hole on the bottom for the brake line. It's best to check every step in the fuselage plans to make sure you don't miss anything.
Kevin Lippert
Zenith 750 completed 2016 -
Sold
N1402 reserved
RV-14a Airworthiness 02-13-2020
New Build Log
Old 04-03-2019, 09:15 AM
bkervaski's Avatar
Check the forward top canopy seal .. http://www.vansairforce.com/communit...d.php?t=167134
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 04-03-2019, 10:40 AM
Thanks for tips. The QB has the same fuel tank sealant issue you pointed out. Likely would never have known about it until the eventual “pop”.
Don Mosier
Cubcrafters
Old 04-03-2019, 02:42 PM
Jake14 Jake14 is offline
drilling the corners of the gear slot and then using a dremel tool with cutting wheel between the drilled holes worked for me. Then filing things smooth.
The dremel tool with cable extension came in handy for several other cutting/sanding jobs in tight spaces.
RV-14A #140158 flying
Old 04-04-2019, 06:26 PM
jdmrv7a jdmrv7a is offline
"drilling the corners of the gear slot and then using a dremel tool with cutting wheel between the drilled holes worked for me.
I used the same process and it worked well.
RV14-A QB
Factory Lycoming IO390 X, HZ CS 2 Blade,
Garmin Dual G3X 460, GTN 625, A/P 507,
GTR 200 & 20 COMM's, 245 audio, GTX 45R
Repairman Certificate
