  #331
Old 04-23-2019, 08:27 PM
Jeff Vaughan's Avatar
Jeff Vaughan Jeff Vaughan is offline
Default Help my arms are too short
Simple low cost extended vent knob
Jeff Vaughan
RV 12 N237VW ELSA
RV 7A N561EV Sold
West Chester Pa
2020 donation current
Old 04-25-2019, 09:27 AM
PilotBrent PilotBrent is offline
Jeff, at first I thought you flew into a flock of baseball bats!
Brent Connelly
Hackettstown, NJ
RV-12, N913BC
http://www.mykitlog.com/brent45
Check out & subscribe to my Youtube channel for latest RV-12 flying videos...
https://www.youtube.com/channel/UCxQ...Px2I7jmazGdLqg
Old 05-05-2019, 06:09 AM
bernsbm bernsbm is offline
Vent controls...
Barry Bernstein
N12BB RV12 flying since Oct 2016
N122B RV12iS started Dec 2019
2020 dues paid. Best bargain in aviation!
Old 07-22-2019, 02:06 PM
WingedFrog's Avatar
WingedFrog WingedFrog is offline
Update on the effectiveness of the relocation of the Ducatti Regulator.
My relocated regulator has now 150 hours and going. The previous one failed at 100 hours on Hobbs.
Originally Posted by WingedFrog View Post
After many failures of the Ducatti Voltage Rectifier/Regulator due to overheating VANS decided to relocate it inside the cockpit to improve the cooling. I decided that a better option was to relocate it inside the cooling tunnel. Here are in a few pictures the steps I took to achieve the relocation:
The components I used, an Al angle 2X2 1/8" thick with one side cut to 1"wide and a counterplate also 1" wide:
Cuts in the fiberglass of the tunnel:
Regulator secured on the angle:
Regulator installed inside the lower cowl's tunnel:
Lower Cowl in place with Regulator connected including a ground cable:
The ground cable goes to the battery housing:
As I decided to leave the initial connector untouched, I connected the extension I made to reach the tunnel with spade connectors but I had to secure the spade connectors with tie-wraps or risk a damaging disconnection of the alternator. On the picture you can see the stand-by Regulator located at the initial location on the firewall. In case of failure of the active located in the tunnel this standby unit can be switched into active by disconnecting the failed unit and reconnecting the standby.
Builder's name: Jean-Pierre Bernoux
Sport Pilot
Kit # 120395 N124BX
Flying as of 9/11/2013
Builder's Blog:http://vieilleburette.blogspot.com/
EAA 1114
Old 11-20-2019, 07:58 PM
ben barron ben barron is offline
Default SILENT HEKTIK INSTALL COWL RAIN CAP
MY SOLUTION TO RAIN AND MY NEW SILENT HEKTIK VR INSTALLATION IS ATTACHED
[IMG]https://cliseproperties.box.com/s/wq9m35vnz5xutdw15fp8yglwe2g5ie4f[/IMG
https://cliseproperties.box.com/s/lo...348l6tia2414pn
https://cliseproperties.box.com/s/g9...br1lsxkxbl06x8
B2RV12
Old 02-08-2020, 07:18 PM
rolick22's Avatar
rolick22 rolick22 is offline
Default CO detector
Just installed a new Aithre Shield EX 2.0 Behind-the-Panel Carbon Monoxide Detector. Works great and looks great easy install. Integrates into the G3X touch via the GEA-24 50 or 37 Sub-D connector.
___________
David Rohrlick
PPSEL, A&P
RV-12iS Completed
Airworthiness signed off by the FAA 1/23/2020
Need:
Test flight and Phase I
Paint?
Serial#12-0864
N112DR
VAF donation made for 2020
