Old 07-21-2019, 11:14 PM
lr172 lr172 is offline
Originally Posted by Cayugarandy View Post
I use an engine prelube tank,like the one Goodson.com sells.I put all the oil I want in the engine,in the tank,and let air pressure push everything into the engine.Rotating the engine slowly will lube everything while pressurized.Not hard to build your own if Goodsons is too pricey.
It won't lube everything. Many parts, including the cylinder, pistons, cam lobes, accesory gears, etc. are lubricated via centrifugal splash from the crankshaft (specifically oil fed to the rod journals) rotating at 1000+ RPM. Acc gears get splash from the oil fed to the idler gears and then slung to the other gears via centrifugal force, as well as a bit of splash from the cam gear which it gets from the aft cam journal .
There is a reason that all engine manufacturers use fogging/pickling instead of recommending approaches like this.
N64LR
RV-10 in Phase I
Old 07-22-2019, 06:09 AM
Taltruda Taltruda is offline
Default Preoiler
Found some specs on a commercially available pre Oiler...http://www.oilamatic.com/specifications.htm
Tom
Las Vegas
RV-8 empenage started..
Horizontal Stab done! 2-15-2020
