Old 04-30-2019, 07:52 PM
Jake14 Jake14 is offline
Default rudder pedal mod
The brake feel on my 14 seemed less than ideal. The flat pedal seems to make you point your toes to apply pressure and a wet sole can cause slippage. Also, it's hard to tell how high to raise your foot for braking; if you raise it too high, your toe hits the hinge bar and causes loss of pressure.
I've also been noticing some after-market pedals which seem to separate the brake and rudder portions of the pedals for a more positive braking action, which seems like a good idea.
I attached a couple of angles to the pedal surface (see pic) to see if it improves things and the difference is very noticeable. I now can tell where on the pedal my foot is located and the braking action seems to be much more positive and even.
Not saying it's something we should all do, different folks have different ergonomics so it may not be an improvement for everyone, but I'm looking for some hard rubber strips I can attach to the angles and make this a permanent change....
RV-14A #140158 flying
Old 11-14-2019, 08:33 AM
algrajek algrajek is offline
Can You RE send the pics?
Al "Nordo" Grajek
repeat offender
\___(0)___/
RV8
RV8A
RV8
RV6A
Now RV7A!!
Old 11-14-2019, 10:43 AM
gereed75 gereed75 is offline
I assume 6and 14 pedals a similar. I have angle on the bottom of my pedals after experiencing ergo issues similar to you.
500 hours and hundreds of landings latter - no rubber, no problems. Keep it simple. Fly on.
Gary Reed
RV-6 IO-360
WW 200 RV now an Al Hartzell for improved CG
Old 11-14-2019, 06:47 PM
I'll re-post this weekend when I get back in town
Old 11-17-2019, 07:08 PM
here it is, I haven't added any rubber pads, it works fine the way it is
https://imgur.com/R4iijwe
Old 11-18-2019, 12:43 AM
gen1313 gen1313 is offline
I have exactly the opposite problem. Because my legs are very long my knees are bent so that I have trouble staying off the brakes when applying pressure to the rudder pedals.
I fitted the JD Air rudder pedal extensions to the bottom bar. They worked very well.
Graham Haley
RV-14 #140181
Flying 5th January 2017
230+hours now
Old 11-18-2019, 07:25 AM
B Cunningham's Avatar
B Cunningham B Cunningham is offline
+1 for JD Air.......
Ben Cunningham
RV7 N701VF
Bowman Field, Louisville, KY
