OK Guys, all valid points. First Bruce, by definition Lycomings are not prone to carb ice due to induction air flowing through the oil sump full of hot oil. Remember, this airplane has 1500 hours on it and has been safely flying for 11 years. All of the hours were flown by me, a bunch in the idaho backcountry and Alaska and I fly above 10K alot, a few hours in visible moisture below 50F where the FAA says Carb ice may form. It has been tested, just a bit...
I was very fortunate as a young commercial pilot to fly over 3000 hours behind little Lycomings in little airplanes before flying fighters in the USAF. In all those hours I have only had carb ice symptoms twice. Both times in Bellanca Scouts in light rain at 35- 45 degrees F. I have only had symptoms twice in 11 years in my RV4 and both times the alt air filter position cleared it up. The filter sits very close to the sump, a very warm area. Trust me, it works. ( I have grandkids I like would like to see grow up!, yes I take precautions) Of course no carb ice compares to 100MM bullets going by your canopy, cruising at 400 knots at night...but that's another story. It's my airbox, it works, it's simple and I like it...
Next, the quick drain is not safety wired closed, but it is safety wired on the sump. I connect a rubber line to it for oil changes, push in and go...
The Odessey Battery setup has 400 hours on it with no problems at all so far. Helped CG, shortened my wires, opened up free space for storage inside, works good. Hot starts, cold starts, whatever.
Questions?
Hope all this helps...
Faithfully Submitted...
Rob Ray
