RV6 Panel Bow part number?
dmat
Advertiser
I have been trying to find the bow on the back of the panel on Vans but can't find it. Honestly, I don't even know the actual name of it let alone the part number.
Any help would be greatly appreciated.
D
If you are referring to the structural support riveted to the back from lower, left corner to right corner, that is builder made from stock 3/4" angle. Can't remember if it was 1/16 or 1/8.
I don't believe there is an actual part number. You get to fabricate this part out of a 3/4 x3/4 inch 0.062 angle aluminum strip. You will drill a bunch of holes, cut out the required aluminum "bridges", and form the resultant part to conform to the instrument panel and then rivet the brace to the panel.
