What size solder sleeve
lr172
I would like to use solder sleeves for attaching pigtails to shielding, but have no experience with them. Can anyone tell me which size sleeves to order for 2 and 3 conductor shielded tefzel?
Hi Larry,
I find they come in 4 colours:
White are very thin and useful for joining 2 thin wires (AWG 24 to 20)
Red are bigger and for joining 2 thicker wires (20 AWG to 14 AWG)
Blue I use for joining shielding wires in 2 / 3 / 4 cables
Yellow are too large for most things but occasionally I use them when I have lots of wires bunched together
I would get blue ones for shielding and reds for general purpose wire joining.
Happy soldering !!
Amer
Solder sleeve with integral pigtail
Take a look at Steinair. He has the solder sleeves in different sizes for shielded wire with the pigtail already built-in to the the sleeve (also without the pigtail).
They work very well to terminate the shielded wire.
https://www.steinair.com/?search_category=&s=solder+sleeve&search_posttype=product
Also see the solder sleeve video on this page for installation instructions. A lot of great wiring videos/tips on this page.
https://www.steinair.com/documents-and-support/videos/
Andy
My opinion so take with a grain of salt. I view solder sleeves as a waste of money and clunky. Soldering a pigtail to a braided shield wire and covering with a piece of heat shrink is a very simple task.
That is what I did on the 6, but this G3X system wants a LOT of shielded wire (many terminated on both ends) and I thought this would save the hassle of soldering in place in the plane.
Andy
Looking at the stein site, each of the different sizes is blue :confused: Do you know the fractional size of the "blue" sleeve that you recommended 2-3 conductor?
The blue TE connectivity one's that I had identified at Digikey were .180" Does that sound right?
When your laying on your back, feet up in the air over your seat backs, under the panel, it is a viable option.
I agree with Carl otherwise, but I have a couple sleeves where putting a heat gun on it was much easier than trying to solder.
Steinair’s website lists the recommended wire size the solder sleeves fit in the item description. I just ordered a few today to finish up my wiring on the RV-9A. I just soldered and shrink wrapped my shield grounds on the RV-10 and although it did the job just fine, when I started the 9A I decided to try the solder sleeves. The results are much more professional looking and the sleeves have a built in ring of hot melt glue to help secure the shrunk sleeve and pigtail wire. Yeah it builds the cost of your avionics wiring,,,,,maybe even by $60 or so, but when your spending around $30K plus for your avionics and wiring, that’s a small amount for the simplicity and professional results you get! It’s much faster also.
Pigtail
To each their own. I love solder sleeves on shielded cables.....
Me too. About the pigtails on some solder sleeve, on the ones I bought, the pigtail is just a bit of wire that's been melted into the solder ring, so making your own is exactly equivalent. I assume it's this way for other brands, so basically, it's a very minor convenience. You can use your own bit of wire in there as a pigtail and it's exactly the same.
PLUS 1
Until last year, I had agreed with Carl. But then I tried the sleeves. Fantastic. High confidence in a solid joint, fast, easy, no muss, no fuss. I'm a convert.
I agree, but the problem I had was holding everything in place and using the heat gun at the same time - simply not enough hands. :)
I found this type of tool pretty much essential -
extra hands
Yes, these extra hands are very helpful. I got one with a magnifying glass but it fell out. Still useful.
