-8 Aerosport Power IO-360
Working on FWF and shooting to have ZERO tie wraps FWF.
The best money I've spent on a tool is the Adel Clamp Tool from AS.
But it needed a bit of a work. With a correct length AN3 or screw, washer and stop nut, the jaws were just too thick to catch the nut. It also had a very rough casting so a lot of friction and hard to remove after catching just a couple threads of the stop nut.
A few different grades of files, course to fine, to take off a few thousands and bevel the jaws, then the ScotchBrite wheel to clean it up (both sides) and it works like a Champ.
