Old 04-08-2020, 05:15 AM
BobbyLucas's Avatar
BobbyLucas BobbyLucas is offline
Thanks for the clarification on the soap. Guess I have to go remove and wash some hardware.
Also thanks for the info on what Boelube is made of. I've got a block of paraffin I could rub the threads with. Fresh out of glitter-infused cetyl alcohol though.
...or I can pretend to have some patience and wait until my order arrives Monday. Ugh. I got the 1.6 oz push tube version.
On a related note, did you know WD-40 is the lube of choice for machining aluminum? At least according to all the YouTube machinists I watch.
Bobby Steinmetz
Van Buren TWP, MI
Student Pilot, Mechanical Engineer
RV-12is Empennage Kit, Fuse Kit, #121228
N781PT Reserved
Donated 2020
Old 04-08-2020, 07:01 AM
bobnoffs bobnoffs is offline
what's the rest of the recipe? i think cetyl alcohol exists as a solid at room temps.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
Old 04-08-2020, 07:48 AM
Default Water..
I forgot to add, we just used a little water, blend it up into a paste. As soon as any heat builds during drilling it gets very fluid.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 04-08-2020, 07:54 AM
vlittle's Avatar
vlittle vlittle is offline
I have a candle that I use for screw threads. Won't foam into a nice rich lather, though.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 04-08-2020, 01:51 PM
JDeanda JDeanda is offline
Default Beeswax!
An old WWII US Navy Aviation Metalsmith taught me to use beeswax. Itís a good lubricant, no odor that I can detect, melts at just the right temperature, and itís very low cost.
Old 04-08-2020, 01:57 PM
scsmith scsmith is offline
Yes, WD-40 is good for machining aluminum. I would not call it a lubricant though. It somehow removes aluminum's affinity to stick to itself. An old-school model-maker at IBM taught me that when I was a student intern there. He used it as the coolant when grinding aluminum. (need to have the right stone too, of course). But in a pinch if you must use a grindstone on aluminum, keep it saturated with WD-40 and it won't load up the stone (much). ** Note this is considered a dangerous practice for course carborundum grindstones, because the aluminum can imbed in the stone, then expand when it gets hot, and shatter the stone. **
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 600
also LS-6-15/18 sailplane
VAF donation Jan 2020
Old 04-08-2020, 02:25 PM
wirejock's Avatar
wirejock wirejock is offline
Default WD-40
I was told WD-40 was basically Varsol. I think it's a solvent.
My spray preference is Blaster. Excellent multi purpose lubricant. Blaster Catalyst is great for stubborn nuts and bolts
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/03/2019, plus a little extra.
Disclaimer
Old 04-08-2020, 03:22 PM
Freemasm Freemasm is offline
Default Penetrating Oil
Was going to thread drift a bit as PB Blaster was mentioned but I'll start a new one instead.
Old 04-08-2020, 03:24 PM
wirejock's Avatar
Default Blaster
Several different products from Blaster.
Larry Larson
Estes Park, CO
Disclaimer
