Old 04-05-2020, 02:42 PM
Bart Bart is offline
Default AN-509-10R25 Aileron attach screw
Just curious how other builders have attacked the number 10 screw attaching to the aileron control linkage. Its a countersunk screw yet my QB aileron does not have a countersunk hole and I see no directions for countersinking the bracket it goes through. The clearance seems fine for the flap although the screw is tight going in but leaves about an 1/8 inch of the screw head out without the countersink. When I look at it I would think an AN-3 bolt would actually do better here.
I have seen other builder sites that apparently just leaves the countersunk screw into the non-countersunk bracket hole. Is this the consensus? Have others just used an AN-3 bolt? For the ones who used the number 10 screw was is tight going into the nut plate as far as you could get it with it being countersunk? For the builders that decided to countersink the bracket did you think the bracket was too think for a countersink?
Hope this makes sense...I have built a -10 and find the -14 plans to be somewhat lacking in areas. Mildly frustrating.
Old 04-05-2020, 03:33 PM
TASEsq TASEsq is offline
Page 22-03 Fig 2?
___________
Trent Stewart
Melbourne, Australia
http://www.tasrv14.blogspot.com.au/
May 2020
Old 04-05-2020, 03:49 PM
Bgill Bgill is offline
Default 22-03 step 4 Countersink
I think the step you are referring to is pg 22-03 step 4. Mine was not a Q/B so I countersunk earlier. The part has a doubler behind so see no issues with the C/S. It fit up fine when assembled.
I would C/S and use the AN509 screw. Wouldn't want to take a chance on rubbing later when things wear a bit or after paint or some other minor change.
Byron
RV-10 40253 N253RV Flying
RV-14 140466 In build - Finishing kit
Douglas, GA. 2019 Dues paid
Old 04-05-2020, 04:35 PM
JTJones's Avatar
JTJones JTJones is offline
Default I agree
I agree with TASEsq and bgill. Also look at plans page 23-10.
Jeffrey T Jones
RV-14 N588TJ Completed
First Flight July 10, 2018
Flight testing completed August 14, 2018
2019 VAF dues paid plus beer money😜
Old 04-05-2020, 05:24 PM
MS19087's Avatar
MS19087 MS19087 is offline
Default Just did this yesterday
My QB Wasn’t countersunk. No problem. Just countersink and move on.
RV-9A; N91RV Sold
RV-14A; building
2020 =VAF= donor
Old 04-05-2020, 06:47 PM
Default Its a QB issue
Thanks folks...I decided to review the slow build and found my QB did not have the appropriate countersink. Got it now and things went right in as advertised.
